Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Dishwasher Help Required!!!!!
- This topic has 4 replies, 3 voices, and was last updated 18 years, 9 months ago by
PE.
July 4, 2007 at 7:57 pm #28733
PE
ParticipantHello,
My first post, great site & great advice!!
I need some myself, all help appreciated.
I have a Whirlpool ADG957 integrated dishwasher(5 years old, and never a problem).
About 2 weeks ago, it simply stopped working i.e when it’s closed, there is no sign of life. Hence, there is no flashing light sequence to identify the fault.
I have checked the circuit board and power is reaching it (it is a Dreefs circuit board). Despite power, there is absolutely no sign that the unit works.
Basically, has anyone got any ideas? Should I cut my losses and buy a new one or can it be fixed?
I’m bemused. Please help!!!!
July 4, 2007 at 8:16 pm #219831Penguin45
ParticipantRe: Dishwasher Help Required!!!!!
Door switch? Nothing will happen if it thinks the door is open.
July 4, 2007 at 9:10 pm #219832PE
Thanks for prompt reply Penguin. much appreciated 😀
Re door switch, everything seems to be in order there.
The lights on the control panel are not illuminating ie to switch cycle, on/off etc even though power is reaching it. Hence, no fault identification.
Basically, power to control panel ok (I tested this)- no lights illuminating (lights would have illuminated when door open previously eg to set wash)-
when press “on” switch and close door, no response i.e. water not entering machine, no sound of pump etc.Maybe it’s cut losses time????
July 4, 2007 at 10:06 pm #219833clivejameson
Sounds very much like the pcb has let go then, they are around the £100 mark but some can be repaired for significantly less depending on the nature of the fault.
I would recommend that the rest of the appliance is tested for earth leakages though as it’s entirely possible that an earth fault has damaged the pcb. At only 5 years old it’d be worth repairing IMO, especially when you compare it to the cost of replacing an integrated unit 😉July 5, 2007 at 9:47 pm #219834PE
Thanks for the help folks.
Think it’s the pcb alright. Was hoping it wouldn’t be!
