Dishwasher Hotpoint BF71 ‘F’ code and continuously draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher Hotpoint BF71 ‘F’ code and continuously draining
  • #94107
    pmcloughlin10
    Hello
    My dishwasher had a code ‘F’ appear on the button and continually kept draining and water collected in the exit drain. The dishwasher had finished its cycle and had cleaned the dishes but did not finish the cycle. Turned it on this morning and the ‘F’ code is still appearing and the draining noise.
    Anyone have any ideas what is wrong or how it might be fixed??
    Many thanks!
    #456469
    Re: Dishwasher Hotpoint BF71 ‘F’ code and continuously drain
    A Bosch based machine, error codes are usually given by showing E and a number but your symptoms suggest a flooded base.
    You will need to drag the machine out, unplug and then tilt it to one side or backwards. I water runs out then this confirms the base is flooded. You will then need to find the source of the leak.
