dishwasher hotpoint not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum dishwasher hotpoint not draining
  • #94625
    washingthedog
    Hi all.
    I have a Hotpoint dishwasher FDEB 10010 EXPERIENCE.
    It is not draining water. I have cleared the filters and not found any debris and I cant seem to find the propeller that should be twirlling? Is there one accessible on this model? I have removed all the filter and little black plastic covering that covers the outlet.
    Also is there a button sequence I can push to get the pump to drain the water or flush the tubes beside turning it on and off again?
    Thanks for any help.
    #457865
    Re: dishwasher hotpoint not draining
    1 no there is not a button sequence to make it pump you just have to cancel and restart the programmes
    to access the pump you have to take the dishwasher to bit to be able to take the pump apart to clear the obstruction
    I take it there is silence from the pump when you try to operate it
    if the pump is running then the blockage may be elsewhere
    washingthedog
    ok, thanks for that.
    The pump seems to be ok. I see no impeller like in other videos on youtube. Im going to try a baking soda and vinegar solution down the pipes to see if it clears.
    #457867
    do not put anything down it !!
    there will be a pump impeller you just not looking in the correct place
    this is the pump for you machine in the site spares store
    https://shop.ukwhitegoods.co.uk/c002723 … drain-pump
    as you can see it does have an impellor
