Dishwasher leaking
  • #97304
    Redhouse01
    I have a hotpoint integrated dishwasher. It’s the second dishwasher with the same problem. The first dishwasher was leaking just below the door. It had a new bottom arm & a new door fitted & it still leaked. The engineer then said we need a new machine. Two days after the new machine arrived we have the same leak. Has anyone had the same thing happen to them? What did you do about it?
    #467017
    andyjawa
    OLD post. Most likely got nothing to do with the door or component failure but on a pump out the stand pipe is blocked-up and the water bubbles over the top, hits the floor then runs towards the front giving the impression the actual machine is leaking when it is not or the pipe has a split in it which is fairly common.
