Dishwasher leaking into tray
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher leaking into tray
  • #91761
    Davecole
    My two year old AEG FAVORIT55500WO dishwasher has started to discharge water through the flood prevention tubes into the tray, operating the float switch. The door seals look to be clean and supple and the filters are clean.
    I have dried the tray and run the machine on a 30 min cycle, it appears to fill normally, but as soon as it starts to wash, water runs out of the above tubes putting the fault code 30 on the display and draining the machine.
    I am at a loss to diagnose the problem and would very much like your help.
    #449155
    Re: Dishwasher leaking into tray
    will need the pnc number to check but a lot of these units are subject to a modification on the pressure switch that controls water height
    Davecole
    Where would I find the pic number? The only numbers I can find are on the label on the back that says:
    DATA
    04-04-2014. 08:52
    NR L:01
    SN:0000446896
    The only other number is on the side of the label and is 214
    #449157
    there is normally a label on the door
    have found it but there are 10 with the same model number
    the attachment is from pnc number 911516142 / 02
    I would assume it covers the whole range so check your sump to see if its been modded
    Davecole
    Thanks, found it!
    PNC 911 516 162 00
    S-No 41529682
    #449159
    yes yours is covered by the mod
    par number 4055346060
    https://shop.electrolux.co.uk/c/Dishwas … 4055346060
    Davecole
    Thanks, I have ordered the parts and will let you know how I get on.
    Regards.
    #449161
    Davecole
    Hi, one further question.
    Once all the componants are installed, how do I carry out a line test to calibrate the correct parameters of the pressure sensor.
    Do I need any special equipment?
    #449162
    the one I fitted worked first time but other people have talked about putting water in so when the machine pumps out first it will realise its empty
    I would try it and see
    Davecole
    Modification parts fitted, all up and running fine.
    Thanks for your help.
    Regards
    Dave Cole
