An Elecrolux ES16104x S.N. 911841114 has recently had now sump seals fitted, the machine was put upside down to replace parts and is now locking out on the inlet valves. All presure hoses have been cleaned out and re fitted. Clicking round the selector switch will start the wash cycle for approx 1 min and then the appliance will lock out again. Does anyone have any suggestions? Many thanks. 🙂
I have had this problem on a similar model. After checking all the pressure tubes are clear of water I turned off the water, then loosened the hose union to release the water pressure from the inlet hose, water back on, then all was OK
