dishwasher no heat
  • #16368
    bigred
    hi
    diplomat d/washer mod adp 8224
    this machine runs for about 10 min on a program but does not heat
    just emptys & fills like it just rinses.
    it does not show any error codes , stops as if the prog has done.
    any idea’s thanks
    #169543
    tintin
    Re: dishwasher no heat
    There is a few things that can cause that,but I would check the heating element 1st,might be open circuit.
    #169544
    bigred
    the element & stat test out ok
    #169545
    Dave_Conway
    If there’s definitely no error code on the LCD display then it points to the PCB itself to be honest 🙁
    There are other factors though that can cause software errors on these, I would recommend an engineer on this one as the PCB is over £100 and a wrong diagnosis could prove costly, check the repairs@ link below 🙂
    If you do procede, power off please when checking :zap:
    #169546
    bigred
    ran it through another prog got warm on wash but completed too quick
    with no dry at the end.
    so it does look like PCB is up the creek 😆
