Dishwasher not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher not emptying
  • #74751
    hoolie4
    Help! I have a Zanussi ZDF 231 that is not emptying it just makes a buzzing noise the goes into fault code 2 flashing neon’s (which manual says sink spigot blocked, hose blocked or twisted)
    I have tried all of these and they seem fine.
    I have:
    Disconnected the drain hose and slowly emptied tried blowing into the drain hose.
    Removed the RH side panel and ran wash cycle all fine but still won’t empty.
    Tried plunging with a cloth in the sump under the strainer and could hear a sound like a valve closing and opening! Can any one help.
    #392753
    Re: Dishwasher not emptying
    But have you checked the drain pump?
    #392754
    hoolie4
    Not sure where the drain pump is, the drain hose goes into the plastic drain section but it is right in the centre of the machine do I have to dismantle more to access?
    #392755
    hoolie4
    Just realized there is a plastic panel underneath machine I can access, will check .Thanks
    #392756
    Lie it only on its back to access the drain pump!
    #392757
    hoolie4
    Thanks Martin Have managed to get to drain pump ended up taking off a plastic panel under the front of the machine and tipped on side, actually much easier than first appeared.
    Found a pistachio nut shell in impeller Fingers crossed it will work now.
    Tools used, Philips screwdriver pliers and a golf ball.
    #392758
    hoolie4 wrote:and a golf ball.
    Odd tool to use I must admit but easier on the pump than a lump hammer I’m thinking?
