Hi all.
I have had a CDW45W10 currys essentials dishwasher for about 3 years which has developed a fault.
A few minutes after starting up it starts making what I can only describe as a pulsing noise but doesn’t do any more than this. When I open it to check there is evidence of water having been sprayed but not much, also sometimes the dispenser is open and sometimes it is still closed. I close the door and restart it and after a few minutes the same thing happens again. It will work on the rinse and the soak program but not on any of the wash ones. I’ve checked the filters and they’re fine.
I’ve checked the manual but nothing like this is listed.
Thank you
there seems to be 2 different boards depending on serial number. the wholesaler I looked at quoted a retail price of about £60 plus vat but it may well be got cheaper. plus fitting if you cant do it yourself
you could ask the site shop to see if they can supply
