Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › dishwasher problems
- This topic has 6 replies, 4 voices, and was last updated 19 years, 5 months ago by
garrry.
November 2, 2006 at 12:53 pm #22215
garrry
ParticipantHello guys. My dishwasher no longer uses the tablet and therefore does not clean. It seems that the tab hatch no longer opens on itsown. Is this common. what causes it and how can it fix it or get round it. Any help or sugestions would be appreciated. thanks
November 2, 2006 at 1:04 pm #194076Martin
ParticipantRe: dishwasher problems
garrry wrote:It seems that the tab hatch no longer opens on itsown. Is this common.
Now you’re not winding us up here are you? No of course not 😉
OK, assuming the latter, your dispenser doesn’t work and needs replacing. So if you give us the Make and Model number we most likely can assist you further 🙂
November 2, 2006 at 1:28 pm #194077kwatt
KeymasterRe: dishwasher problems
Hi Garry,
You could also just put the tablet in the cutlery basket instead and save yourself £40-70 on a dispenser and the hassle of changing it. 😉
November 3, 2006 at 10:27 am #194078garrry
thanks for a rapid response. It’s a seimens, as for the model i,m still trying to find out. I tried putting the tablet straight into the cutlery basket, and it still left all dirty. but if this option can work what is the point in the dispencer
November 3, 2006 at 7:57 pm #194079Penguin45
Model number will be engraved in the top edge of the stainless steel door on machines up to ten years old, before that, it was on a label on the cabinet edge, just below the lid.
November 4, 2006 at 9:23 am #194080garrry
thamnks again, having read about other peoples problems i think it might be a lack of water pressure. I live in an old farm house with no mains supplier, the water is piped from an underground river. its the hardest in the cuntry (apparently) measureing 9 on the ec meter. But this confuses me, as i,v read that the washer uses and recycles a pool of water from under the cabnit. then why does the preasure from the sprinkler arm jets rely upon mains preasure surly this would be an internal pump. Having said this i have read posts from others who cannot have a dish washer due to lack of preasure. I (perhaps dangerously) pushed the door catch in making the washer think it was shut and watched a snippet of the wash. The bottom sprinlker arm spayed about 7 or 8 inches high, is this enough and the top just dribbled out. could this be preasue or broken pump.how can i test the preasue. can should it be feed by hot or cold. so many questions i know. Heeeeeeeeelp!!!! please
November 4, 2006 at 5:24 pm #194081Penguin45
How can we help you when you won’t tell us the MODEL NUMBER?
Penguin45. -
