tricity bendix DH102D; This dishwasher has suddenly begun to spill water at the right hand side just above the door hinge. Spill or splash rather than leak as it happens at short irregular intervals, with a good quantity of water each splash. The door seals look in good order; the machine does not seem to overfill.
Any one experienced this before?
Any help/ suggestions welcomed.
thanks in advance,
tom
Check the rotors for splits along their seams – during wash the pressure in the rotor can open up a split and spray copious amounts of water straight at the door bottom seal causing large intermittent leaks. Door seal will show no signs of failure. Leak ‘timing’ will generally be equal to the speed of the turning rotor .
Common on Hotpoint machines. 😉
