Dishwasher teka dw6 59 FI problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher teka dw6 59 FI problem
  • #52475
    ironman2010
    I have a dishwasher teka dw6 59 FI and yesterday I ahve a problem with it. The three first lights were blinking and the fifht one is fixed. Then I push the selection program button. The ligths disapears and only one is fixed.
    The machine works for a while (2 or 3 minutes) but suddenlly stops with a bip and the three lights blinking again.
    I think I need to reset the machine but I don’t know how to do that. Can you help me?
    Thanks.
    #311940
    Re: Dishwasher teka dw6 59 FI problem
    Switch on and press the programme button 4 times, within 3 seconds. The 1st and 5th lamps should light…….. You may have to do this several times before it works! Assuming that it does, switch off, count to 10, switch on and run the rinse programme only.
    ironman2010
    Thanks but I made what you say (press the button 4 times within 3 seconds) several times (50 or more) and nothing. It’s hard! Is it normal?
    #311942
    If the machine absolutely will not re-set, you may be faced with a corruption issue, something which these SMEG-built machine are particularly prone to. This ARTICLE may prove to be of interest.
    ironman2010
    I can’t solve this problem. I can only fix the last two lights…
    This error occurs after I open the door of the dishwasher when it begins to wash (2 minutes, I think).
    #311944
    dourobyte
    ironman, I have the last 2 lights problem…
    can you please help me?
