Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Dishwasher Thermostat Failed Twice
- This topic has 9 replies, 2 voices, and was last updated 14 years, 6 months ago by
Bazil74.
October 19, 2011 at 6:28 pm #65751
Bazil74
ParticipantHi All,
I have a Matsui MF145 slimline dishwasher that is about 3 years old. Up untill a few months ago had no problems. About 3 months ago it was not getting hot and found one of the thermostats to be open loop, replaced both and worked fine. Now about two months on the same thing has happened and the same thermostat is open loop again (presume this is the one shot thermostat?). So not sure if I should replace again and see what happens or something else at fault??
Any ideas??
Thanks in advance
October 19, 2011 at 7:48 pm #361730admin
KeymasterDishwasher Thermostat Failed Twice
Check that you are getting full circulation of water.
Bryan
October 19, 2011 at 7:53 pm #361731Bazil74
ParticipantRe: Dishwasher Thermostat Failed Twice
Thanks Bryan, there is definetly plenty of water when in cycle, certainly enough to cover the heating element does that sound ok?
October 19, 2011 at 8:01 pm #361732admin
What about whilst it’s running?. Take the unit out and watch the water going up the top supply pipe.
October 19, 2011 at 8:17 pm #361733Bazil74
Just checked, feed pipe to top rotating arm is definitely full of moving water when running. I guess your thinking if there is not enough water it could overheat easily.
October 19, 2011 at 8:19 pm #361734admin
Are both paddles spinning ?
October 19, 2011 at 8:30 pm #361735Bazil74
yes they seem to be rotating fine and lots of water flying about when you open the door whilst running. Could it be the control system not turning the heating element off at the correct temp which makes it get too hot and blow the other fuse?
October 19, 2011 at 9:03 pm #361736admin
Normally due to blockage in the paddles.
October 20, 2011 at 7:14 am #361737Bazil74
Ok thanks, I will take them out and give them the once over tonight.
October 20, 2011 at 5:43 pm #361738Bazil74
had both paddles out and look fine, certainly no bloackages when running under the tap. I guess I just fit a new thermostat and see what happens.
