Dishwasher Virgin needs help with a Baumatic please !!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher Virgin needs help with a Baumatic please !!
  • #78919
    BigAde111
    Hi there,
    I have just moved into a rented house and it has a Baumatic dishwasher (not sure of model number as the manual is at home, but I could add this later).
    I have never used a dishwasher before, so bought some all in one tabs and my first 2 washes were perfect. When I tried to do my third wash last night, the washer sounded like it was starting for a minute or so, but then stopped and there was just a low humming noise.
    The “Add Salt” and “Add Rinse Aid” lights are both lit, but I presumed as I was using all in one tabs that I would not have to add these ? Could this stop a washer from functioning ??
    Everything is loaded correctly in the racks, I’ve cleaned out the filter and can’t see anything else wrong.
    Sorry for the lack of info, but I’ve never used a dishwasher before !!
    Any help/info would be greatly appreciated.
    Many thanks,
    Ade
    #407351
    Re: Dishwasher Virgin needs help with a Baumatic please !!
    “Low humming noise” would normally indicate the pump in jammed. 🙁
    Salt and Rinse Aid lights not an issue in this by the way.
    #407352
    BigAde111
    Thanks Martin.
    Is that something that I (a DIY spastic !!) could look at, or do you reckon I should just call the landlord ?
    Cheers,
    Ade
    #407353
    Call the landlord, it is his problem not yours! 😉
    #407354
    BigAde111
    Cheers mate
    #407355
    BigAde111
    Hi Martin,
    Just another quick question if you don’t mind pal.
    The place where you add the salt, should this be full of water ?
    I opened it last night and it was full to the brim.
    Thanks in advance,
    Ade
    #407356
    BigAde111
    BTW, forgot to mention, the model is BDW13
    #407357
    BigAde111 wrote:BTW, forgot to mention, the model is BDW13
    Ooh dear not such a great machine in the grand scheme if things so let your landlord deal with the problem, leave well alone. And yes the salt reservoir should be full of water prior to refilling it with either salt granules or tablets. Most of the water will spill out once it’s topped up. But don’t attempt that until it’s fixed because salt lying in the machine is very corrosive!
    #407358
    BigAde111
    Thanks Martin, you’re a star
