Hello
I want to fit a bosch dish washer model sgs45co2gb.The distance of the dishwasher from the standpipe is 2.4 mtrs. Is this too far for the machine to pump the water. It is not possible to alter the waste pipe because of units being in the way.
*Shouldn’t* be a problem – height is far more of an issue. The only problem I can envisage is that if the hose run is along the floor, you will have a lot of standing water in it – fusty smells could be an issue. Go high early if you can to reduce the problem.
