dishwasher whirlpool adg 934
Home Forums Public Support Forums Help And Support Dishwasher Help Forum dishwasher whirlpool adg 934
  • #50052
    ositopadi
    I dried the flooding and switched on and it quicky filled out with water again and does nothing other than middle left progress light continuously flashing and RHS TEMP selection light remains on.
    PLS HELP. 🙁 💡
    #303146
    ositopadi
    Re: dishwasher whirlpool adg 934
    ositopadi wrote:I dried the flooding and switched on and it quicky filled out with water again and does nothing other than middle left progress light continuously flashing and RHS TEMP selection light remains on.
    PLS HELP. 🙁 💡
    No error CODES nor LED flashes.
    Thank you.
    #303147
    Are you saying that the machine just floods water out?
    ositopadi
    Penguin45 wrote:Are you saying that the machine just floods water out?
    Initially it was flooded, I dried it out and switched back on again, I could hear some water activity and then stops, the whirling noise continues and as explained there is no flashing lights and sits there for ever.
    I hope it helps you to help me.
    Thank you Penguin.
    Help PLEASE, I hope I am not forgotten.
    Cheers.
    #303149
    ositopadi
    Penguin???
    #303150
    No, you’re not forgotten, but trying to understand your problem is difficult.
    The machine has a flood protection system consisting of a polystyrene float and a microswitch in the tray under the machine. If there is a water leak, the tray fills with water and the flood protection system cuts off the programme and runs the drain pump – this may be the noise you are hearing. If you have water on the floor as well, the leak should be pretty easy to find as it will be a big one – hose off or split would be the obvious one to look for.
    I’m afraid you’ll have to pull it out and get the covers off and look – there’s no other way. Power off for anything other than observation.
    ositopadi
    Penguin45 wrote:No, you’re not forgotten, but trying to understand your problem is difficult.
    There is no water on the floor but I’ll pull the machine out and look for obvious.
    Cheers Penguin
    #303152
    ositopadi
    Cheers Penguin
    Penguin,
    I have dried up all water from the tray, cleaned filters with a toothbrush, cleaned all debris from around filter
    – I switched back on again and the start light started flashing non stop, I could hear some activity for 15 seconds and silence the start light still flashing like mad.
    – Any ideas???
    Thanks in advance.
    #303153
    Ositpadi, I’m sorry, but I just do not understand what it is that you are trying to tell us about your machine.
    1/ Is the machine filling up with water and then leaking water onto the floor?
    2/ Or is it not taking the water out of the machine?
    If the start light is flashing constantly, this would suggest a problem with the TEMPERATURE SENSOR, but I cannot be sure based on what you have told us so far.
