Dishwasher Whirlpool ADP5966 code 23
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher Whirlpool ADP5966 code 23
  • #17616
    danriis
    My Whirlpool ADP5966 stopped working yesterday with the timer display show 23
    what can I do?
    //Dan
    #175491
    Re: Dishwasher Whirlpool ADP5966 code 23
    A problem would normally identify itself as “F-” on the display, so not quite sure what 23 is about unless it’s time to run and the programme has “hung up”. You could try clearing it by holding down the start button until you hear the drain pump come on. This should at least cancel the existing programme.
    As to what is actually wrong, I’m sorry I haven’t a clue!
    gegsy
    If at all possible, could you get the 12 digit number off inner of door (below barcode)
    danriis
    Penguin45 wrote:A problem would normally identify itself as “F-” on the display, so not quite sure what 23 is about unless it’s time to run and the programme has “hung up”. You could try clearing it by holding down the start button until you hear the drain pump come on. This should at least cancel the existing programme.
    thx it i running 😆
