Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Dishwasher won’t start and the on/off button beeps instead.
- This topic has 8 replies, 2 voices, and was last updated 6 years ago by
Gangsta Way.
April 9, 2020 at 4:39 pm #97452
Gangsta Way
ParticipantHi,
I am totally desperate, looking for advice. With the Covid, nobody wants to come home to repair my dishwasher. It is a Siemens SN65E003EU/43.I had a problem with the draining pump which I remove and cleaned. Once I plugged it back in, nothing happen and the dishwasher won’t start. Instead the on/off button just beeps every seconde and the reset doesn’t work either.
I couldn’t find a similar problem anywhere else and I hope I will find my savior here!
Thank you in advance for saving my life. I am an alone mother of 3 and I am at my wits end…April 9, 2020 at 5:23 pm #467830electrofix
Moderatorcant find an owners manual for this so you need to find yours
what i am thinking is have you turned on the child lock by mistake ?
info like this will be in your manual
April 9, 2020 at 6:24 pm #467831Gangsta Way
ParticipantSmart idea. I checked, there is none. And the noise from the beep is too “loud” to be normal. 🙂
April 9, 2020 at 7:48 pm #467832electrofix
Moderatorwhen you say you removed the drain pump what do you mean ?
April 9, 2020 at 10:05 pm #467833Gangsta Way
ParticipantAt the bottom of the dishwasher there is a white conical pump. I removed it to clean and then put it back with the gasket. Everything is leakproof since the first intervention.
April 9, 2020 at 10:16 pm #467834electrofix
Moderatoryou can take off the cover inside the sump to clean the pump you dont need to remove it
ok
have you flooded the base so the overflow sytem has operated ?have you disturbed any wires to the pump or surrounding components ?
April 9, 2020 at 10:23 pm #467835Gangsta Way
ParticipantDave, there was element that couldn’t be remove from inside the dishwasher so I had no choice. I always dried the dishwasher before doing the pump removal from bottom. Never flooded near the wire. Not even the floor receive water during any of my trials.
April 9, 2020 at 10:29 pm #467836electrofix
Moderatorthats fine but removing a pump is a mechanical action. its easy to knock things or disturb things
check around the area, remove and replace the wire to the pump and any other connectors that may have been disturbed by pulling wires etc as you removed it
the way you are describing the fault is it was sort of ok before you stripped it
when you removed the pump was there any obstruction ?
dave
April 9, 2020 at 10:31 pm #467837Gangsta Way
ParticipantSure, I will have a closer look and try to see there if any cable has been pulled too much and let you know. Thanks.
