Dishwasher won’t wash
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher won’t wash
  • #66977
    gardener66
    Whirlpool adp 4501/5.
    When switch on it makes noises as if draining, then sounds as if taking water from cold feed. But then stops with grren light flashing – eleven times then repeats. Cannot find error code for this. Tried switching off at mains and on machine and restaring – no go. Also checked drain pipe clear and water feed pipe clear. Any ideas? Thanks
    Ian
    #365804
    Re: Dishwasher won’t wash
    gardener66 wrote:Any ideas?
    I believe it denotes an OWI fault (Optical Water Indicator). Which in English means the water flow sensor detects an error in flow rates OR the base-plate of the machine has flooded?
    #365805
    I think it’s a turbidity sensor in the base Martin next to the heater.
    Yes ‘water flow sensor’, ‘optical water indicator’ or ‘turbidity sensor’ or some such is the likely problem here. 😀
    #365807
    gardener66
    OK – thanks both. Is this a case of replacing the OWI …. and how complicated is this? Also how do I check if the base plate is flooded …. there doesn’t seem to be any surplus water at the bottom of the dishwasher (under the metal plate at the bottom).
    Ian
