dispenser drawer not working correct, only fill 1st compartm
Home Forums Public Support Forums Help And Support Washing Machine Help Forum dispenser drawer not working correct, only fill 1st compartm
  • #63903
    shadboy
    Hello every one.
    I have a new Bompani Washing Machine, the soap dispenser drawer is well explained in the manual, 1 for prewash, 2 for wash cycle, and 3 for softener. In all the cycles the machine use the 1st dispenser only for take water, the water only saturate the 2nd compartment(with the soap for the main wash) in the final rinse before the spinning process, that is supposed to do with the compartment 3 with the softener.
    An improvised solution is to use the compartment 1 for place the soap, but I think this is a problem because the water is filling by this compartment at the very beginning in the soaking process, and this first water is drained in some many cycles before the main wash cycle.
    Note that the washing machine is New, I not have guarantee because I’m far in other country.
    Is any solution for this?
    Sorry my bad English.
    #355368
    spanishwhite
    Re: dispenser drawer not working correct, only fill 1st comp
    Bompani I believe is an Indian made machine it is unlikely that anyone will have any tech info on it.
    If you are in the UK your best bet would be to get an engineer to look at it.
    #355369
    shadboy appears to be posting from Cuba?????
    #355370
    shadboy wrote:Is any solution for this?
    :rtm:
    #355371
    shadboy
    Yess I’m from Cuba, Bompani is a italian brand.
    Sorry to every one, problem resolved, or not because it never exist. It was a pinareñada of my part. I confuse the order of the compartment 😆
    Thanks…
