I’m wondering if a faulty thermostat is what is causing my fridge freezer to misbehave? The fridge gets down to 12C, and the freezer to -20C or so, then the compressor does nothing for hours and it comes back up to ambient-ish.
Edit: thermostat is Danfoss 077B3281 B62 -20.0 -34.0, fridge is Hotpoint RFA52
I have taken the thermostat out to test continuity (results as follows), but not being sure of which pin is doing what, I’ve tested each pin against each other, at ambient and then with an ice block held against the temperature sensing tube.
Does this look like a faulty thermostat to you experts?
Many thanks, Dan
continuity test results: (/ohm, high = out of range)
resistance at ambient, to ground
setting…..pin3……..pin4…….pin6
off…………high……..high……..high
1…………..high……..high……..high
2…………..high……..high……..high
3…………..high……..high……..high
4…………..high……..high……..high
5…………..high……..high……..high
resistance at ambient, to pin 3
setting…..pin4……..pin6
off…………0.5………high
1…………..0.5………0.5
2…………..0.5………0.5
3…………..0.5………0.5
4…………..0.5………0.5
5…………..0.5………0.5
resistance at ambient, to pin 4
setting…..pin6
off……………high
1…………….0.5
2…………….0.5
3…………….0.5
4…………….0.5
5…………….0.5
All results were the same when the temperature sensing tube was held against an ice block as well!
