Home › Forums › General Trade Forum › Do you turn dishwashers upside down?
- This topic has 30 replies, 12 voices, and was last updated 19 years, 5 months ago by
andy_art_trigg.
November 14, 2006 at 7:11 pm #194786
aqualectric
ParticipantRe: Do you turn dishwashers upside down?
All this and it was just unplugged in the cupboard!!! :rotl:
November 15, 2006 at 9:52 am #194787andy_art_trigg
Is that the reason you gave the customer for leaving it like that? “free and easy access” for cleaning? I notice it looks like it’s still connected up ready to run lol
November 18, 2006 at 10:03 pm #194788steveDAS
Martin wrote:Notice, if you will, how gravity helps keep all the vital components on the ground for free and easy access! 😉
how long did it take to put that back together ❓ 😥
November 18, 2006 at 11:06 pm #194789bobokines
I’m with Martin on this one. Everything is accessible by simply lifting off the tub. Not a drip on the floor. From this picture, I would say Martin took less than 20 minutes to rebuild..
BobNovember 19, 2006 at 12:44 am #194790Penguin45
I’m a closet (short) Australian………
November 19, 2006 at 7:43 am #194791Martin
bobokines wrote: I would say Martin took less than 20 minutes to rebuild..
Yeah, about 20 mins to reassemble it and slot it back into place. 😉
(As the machine had a mystery leak it took me a good 30 mins to realise I would have to strip it down to fix it. In this case the circulating pump ‘O” ring was leaking but didn’t show up circulating cold water. Only when the water got warmer did it start to leak. I originally thought it must be the carbon faced shaft seal but that was fine but as you know the ‘O’ ring comes as an impellor kit so I stuck the lot in anyway! 🙂 )
November 19, 2006 at 10:36 am #194792bobokines
I’ve had that seal leaking too. It throws you a bit as it only leaks when the circ pumps stops as it’s on the negative pressure bit.
Bob
November 19, 2006 at 10:43 am #194793Martin
bobokines wrote:I’ve had that seal leaking too. It throws you a bit as it only leaks when the circ pumps stops as it’s on the negative pressure bit.
Indeed so Bob! :tup:
Imagine with a tricky fault like that to figure out and you wanted to turn it upside down to get at the motor? 😕
There would be so much water all over the place by then you would’nt have a scooby doo where it was leaking?
:rotl:
November 19, 2006 at 4:13 pm #194794mike412
Hi folks.
I used to be a topsy turvey upside down sort of person, but I have seen the light, yes I am converted, I always lift the tub off now, certainly on this model, its so much easier and in the eyes of the customer, much more professional. I have also had good success lately in chasing these sort of leaks by running the machine with red food colouring inside, then looking for the tell tale bloodstains!. Look out for the pin hole leaks in the stainless steel around the salt filler, had several of those.
MikeNovember 19, 2006 at 6:32 pm #194795bobokines
mike412 wrote: Look out for the pin hole leaks in the stainless steel around the salt filler, had several of those.
Anybody got a long term fix for this problem?
Bob
November 19, 2006 at 7:49 pm #194796iadom
ModeratorRe: Do you turn dishwashers upside down?
bobokines wrote:
mike412 wrote:
Look out for the pin hole leaks in the stainless steel around the salt filler, had several of those.Anybody got a long term fix for this problem?
Bob
Move North, I have never seen a hole in any of this type of machine in any of its many guises. Nice soft water, don’t need salt. 8)
November 19, 2006 at 9:31 pm #194797Penguin45
bobokines wrote:Anybody got a long term fix for this problem?
Granvilles PetroPutty.
November 19, 2006 at 10:23 pm #194798bobokines
Penguin45 wrote:
Granvilles PetroPutty.Is that a two part epoxy putty?
Bob
November 19, 2006 at 11:59 pm #194799Penguin45
Two parts, one stick – cut, fondle until warm and splat. 😯
November 20, 2006 at 8:25 am #194800andy_art_trigg
The Comet engineers only have about 20 minutes per job! That’s why they’ll whip it upside down, take off the bottom panel and get to the motor in minutes.
A different attitude and different methods are forced on some engineers. It all depends on work load and time pressures. As an independent engineer, it’s far prefferable to do a job “propery”, strip it down (and charge accordingly) – but as an engineer working for a multiple or manufacturer, who is often under so much pressure it should be illegal, things are often very different.
