dodgy zanussi FJ1354S
  • #28888
    sandysuds
    Hi GUY,S CAN ANYONE HELP, A ZANUSSI FJ1354S SWITCHES ON OK, DOES 1 WASH OK,THEN NEXT WASH SWITCHES ON PUMPS FOR A MINUTE THEN FLASHES AT START BUTTON ,HAVE CHECKED MOTOR ITS OK , HAVE CLEANED ALL CONNECTIONS , IM BAFFLED BY THIS ONE?
    #220527
    Re: dodgy zanussi FJ1354S
    Easy on the CAPS LOCK there sandy! 😉
    I guess there’s an error code we need to establish here? Apart from the start button flashing, what other led flashes I wonder? Do you have a TDS Disk to run through the diagnostic sequence?
    #220528
    sandysuds
    thanks for the reply martin, the start button flashes and the reset ,no i dont have a disc
    #220529
    sandysuds
    i should have explained this a bit better, its the zanussi with the pbc on the top right hand side , i switch on ,select a program,press start delay button and it will do a full wash ,or 2 or3, then i will switch on select a program ,press start/delay will start for a minute, then the start delay light flashes,dont want to buy a new pbc ,as it may not be that can anyone help
    #220530
    aqualectric
    Always check for a communication fault between the main PCB and the user interface. (facia button board). The edge connector on the user board is a common fault on Delta 3 computer units arising from poor or oxidised contacts. Remove the facia, unplug the edge connector plug (blue wiring) then unscrew and gently pop the PCB out from its location. Clean the contacts of the PCB and gently squeeze the plug with pliers to tighten it. Refit the PCB back into the location on the facia panel, push the edge connector plug back on and refit the facia.
    Should sort it. 😉
    HTH,
    Steve.
    #220531
    sandysuds
    thank,s for all help and advice guy,s,But it workrd for 1 wash and is away again ,start light flashing after a minute
