does a Meile W5740 sense the water temp?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum does a Meile W5740 sense the water temp?
  • #88454
    cypher007
    I basically want to know if the W5740 will check the water temp using a sensor and switch the heating element on and off automatically?
    the reason I ask is Im currently use a TMV, mixing down to about 35C, to feed the machine from our 250L DHW tank that during the summer is heated by solar PV.
    my thinking on this is it must help to reduce the electrical energy used as long as the machine is sensing the warm water rather than just using a timer.
    #438151
    Re: does a Meile W5740 sense the water temp?
    It will do, yes.
    However the amount of electricity you will save for your efforts is minuscule and it will impact wash performance detrimentally.
    Watch your clothes shrink as they gently rinse in hot water. 😯
    #438153
    cypher007
    its not quite hot. only 35c max.
    #438154
    Wash anything delicate in that temperature though and you may well destroy it.
    Wool, silk and other delicate or natural fibres will not like it and even some cottons cannot be washed in water over 30?C.
    Asides which as Martin rightly points out, rinsing with hot is not good at all as it’s cold water that breaks down foam and it’s not good for clothing and it’s extremely wasteful.
