Does a washing machine need a pump (saniflow) if under waste
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Does a washing machine need a pump (saniflow) if under waste
  • #32023
    lbarea
    Hi, I wonder if ayone can clarify the following.
    We are installing a washing machine in the cellar. It will be located 2ft below the waste. I wanted to know whether an external pump is required to pump it up into the waste or whether the pump in the washing machine would suffice.
    Thanks in advance
    Regards
    Laurence.
    #233295
    Re: Does a washing machine need a pump (saniflow) if under w
    lbarea wrote:We are installing a washing machine in the cellar. It will be located 2ft below the waste.
    2 feet is not very low down to warrant installing a Saniflo I should’nt think?
    The drain hose should or could be extended up to a total length of 4 metres to reach that drain? 😉
