Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Does Samsung Series 5 washers remember custom Cycle settings?
- This topic has 3 replies, 2 voices, and was last updated 2 years, 2 months ago by
ralph47.
January 22, 2024 at 8:31 pm #102527
ralph47
ParticipantHi does Samsung Series 5 washing machines remember your custom cycle settings ie Mixed cycle with 60 degrees setting so when you switch the washing machine on and off, will it still mixed cycle program still be on 60 degrees?
I am looking for a washer that remembers the custom settings, not one that defaults back to default settings.
January 22, 2024 at 9:05 pm #489325don
ModeratorI just picked the 11kg WM11BGA046AEEU on the Samsung website at random, it looks like the same manual is for all of them. There is no mention of being able to store a favourite programme.
Don [h=2][/h]
January 23, 2024 at 2:26 pm #489326ralph47
Participantdon wrote:I just picked the 11kg WM11BGA046AEEU on the Samsung website at random, it looks like the same manual is for all of them. There is no mention of being able to store a favourite programme.
Don [h=2][/h]
thanks for the reply, they won’t necessarily mention it in the manual sadly so its something someone has to switch on and test.
I use to have an much older samsung washing machine from 10 years ago but no series tag around £500 but 8kg model and it had the same exact display and menu options, but the key part with that one was it remembered any custom setting ie temp 30 or 60…. so even if you switch it off and then back on the next day and go back to the same cycle it remembers temp 30 or 60 for example. My old samsung manual does not mention this feature either but its there in real life.
So its a hunch of mine that its the same with the series 5 and above and that it should still remember your last preferred setting, I have asked a few others so will update here if I was right or not though.
January 23, 2024 at 10:27 pm #489327don
ModeratorMost electronic machines will remember the last cycle with options you set before you turned it off and it wwill be there when you power up next time. The Ebac washers ( these are another story) and the Hisense washer dryer both advertise the “memory” function I think you are after.
To get everything you want you have to get a smart machine with app.
Don
