Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Door boot springs
- This topic has 15 replies, 9 voices, and was last updated 17 years ago by
dpr1974.
March 26, 2009 at 12:50 pm #44539
dpr1974
ParticipantJust been to do a beko door boot replacement and had real problems with the inner boot spring infact i had to get the customer to help and even then it was a sod. upto a few years ago i had a bloke with me so it was ok dealing with these, but now i’m on my own i need a way to fit them. i usually place the machine on it’s back and if needs be remove the door the problem is i have big hands and can’t always do it on my own, So my question (finally) is there a tool for this? maybe someone has made a tool to do this?
David
March 26, 2009 at 12:57 pm #281336Seamy
ParticipantRe: Door boot springs
I put washing up liquid on the fingers of both hands.
I start at the bottom putting 3 fingers of each hand on inside of spring leaving thumbs & index fingers to work the spring on as I move both hands around the door gasket, works first time for me every time on any of those machines with inner springs, A.E.G, Zan’, Beko etcMarch 26, 2009 at 1:12 pm #281337leavemetogetonwithit
This is worth a read,
http://www.ukwhitegoods.co.uk/modules.p … door+seals
Mike.March 26, 2009 at 2:40 pm #281338dpr1974
Have tried it that way Seamy and it works most of the time, i’m after a something that will help do the job in a few minutes instead of the customer 2hours and gave up attempt, thanks for that link Mike some good ideas there. 😀
DavidMarch 26, 2009 at 4:34 pm #281339robbra
The front of a Beko comes off in 2 mins and makes it a quick job, perhaps 10 minutes max. Door lock and screws behind kick plate and the Sqeezy (showing my age) certainly helps.
RobMarch 26, 2009 at 5:04 pm #281340iadom
ModeratorRe: Door boot springs
Did a BEKO one this afternoon, front panel off, easy peasy.
I did have to do an AEG/Zanussi last week. Customers husband, father in law, next door neighbour etc had all had a go. After making many attempts over several days they gave it up and phoned me.
Thankfully they didn’t want to stand over me and watch, getting the seal on was harder than putting the spring back on, a couple of cardboard wedges and the screwdriver through the doorlock hole did the trick.
March 26, 2009 at 6:16 pm #281341silverbroom
I use two bits of wedge shaped wood and tap these between spring and concrete at 12 o’clock and 9 o’clock position then feed spring round.
silverbroomMarch 26, 2009 at 6:21 pm #281342iadom
silverbroom wrote:I use two bits of wedge shaped wood and tap these between spring and concrete at 12 o’clock and 9 o’clock position then feed spring round.
silverbroomI assume you mean for Zanussi machines. Why anyone would try and fit a Beko without first taking the front off is beyond me, even the ones with the concrete weight round the front should be done that way, only a few minutes longer to take the weight off. :rolls: 🙂
March 26, 2009 at 7:43 pm #281343robbo1973
never had a problem with any of these servis,beko,zan etc etc plenty of washing up liquid and away you go start at bottom with tension and use your thumb to push the top over.had one the other day guy neighbour etc tried for days i was in and out in less than 10 mins.
March 26, 2009 at 8:05 pm #281344silverbroom
Yep sorry iadom, I do mean the Zanussi machines, I to remove the front on Beko also on Bosch but still use the wedges due to a bit of arthritis in my fingers.
silverbroom
March 26, 2009 at 9:54 pm #281345leavemetogetonwithit
robinsonrobbo wrote:start at bottom with tension and use your thumb to push the top over.
Blimey, alright for them with big ‘ands 😆 .
Mike.March 28, 2009 at 5:12 pm #281346Galway
plastic spring clamp from aldi to hold spring on top then feed spring around easy .in and out in 15 min
March 28, 2009 at 5:17 pm #281347iadom
Galway wrote:plastic spring clamp from aldi
Interesting, just what is this clamp designed for, have you got a picture, a link or more info?
March 28, 2009 at 5:44 pm #281348Galway
similar to a stanley clamp model 0-83-086 but the bag i got had alot of different sizes.if you google this you will see what they look like.hope it makes life easier.
March 28, 2009 at 7:21 pm #281349iadom
Nice one, I will look out for them next time I am in Aldi. 8)
