Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Door for Homark oven
- This topic has 6 replies, 2 voices, and was last updated 14 years, 10 months ago by
andrewk7.
June 26, 2011 at 12:01 pm #63590
andrewk7
ParticipantI need a new door for my Homark oven – model number 02-705203. Is such a think available?
Andrew.
June 26, 2011 at 12:25 pm #354224kwatt
KeymasterRe: Door for Homark oven
What part of the door, it won’t come complete?
June 26, 2011 at 3:25 pm #354225andrewk7
ParticipantRe: Door for Homark oven
The top of the outer glass is attached to the door itself by a strip of metal that is rather flimsy. There are 2 screws that go through this strip of metal, through the outer glass and attach to each end of the handle. The strip of metal therefore has quite a lot of strain put on it when you open the door. The metal appears to be galvanised steel. It is this metal piece that has failed – it is split at both ends. It has got to the stage that it is difficult to get the door open at all. It would be nice not to have to replace the whole oven since it is otherwise working fine.
Andrew.
June 26, 2011 at 3:39 pm #354226kwatt
If it’s for the main door it may still be available, about £40-ish but it is a special order part that’d take about a week to two weeks to get.
June 26, 2011 at 3:42 pm #354227andrewk7
I am assuming my “main door” you mean the oven door rather than the grill door. It is the oven door that is faulty. Which part would I be buying and how do I order it?
Andrew.
June 26, 2011 at 4:08 pm #354228kwatt
Hi Andrew,
I can’t get an image of it but this is the metal inner door panel:
And yes, that’s the main oven inner door panel, the grill one is a different thing entirely.
If it’s just that top trim you need though, according to what info I can get and it’s sketchy at best on this machine, I think it’s a white top door glass trim that you mean on the list (I don’t have a diagram of it to go from) and it should be white. But it looks as if that’s no no longer available, like a number of spares now are for that machine so whether it’s worth pursuing or not I don’t know.
HTH
June 26, 2011 at 8:32 pm #354229andrewk7
kwatt wrote:If it’s just that top trim you need though, according to what info I can get and it’s sketchy at best on this machine, I think it’s a white top door glass trim that you mean on the list (I don’t have a diagram of it to go from) and it should be white.
It is not the white top trim but an internal piece that is attached on one side to the outer glass and on the other side to the top of the inner door. There is a thin piece of metal along the top of the inner door but that is fine. The part that is split looks like galvanised steel and is pretty flimsy.
Andrew.
