This oven has a sintered component as part of the hinge assembly.
It’s about 50mm long and 8mm by 8mm square cross section.
Anybody have any idea what it is called or better still a part number. There are two on each door and are all identical, however a different hole is used for fixing the top or bottom door to allow for the varying spring strengths,
