Door Hinge Spring Ariston Oven
Home Forums Public Support Forums Spare Parts Help Door Hinge Spring Ariston Oven
  • #44496
    BrumJim
    Model number: 016704
    LHS Door spring needed.
    Can’t find the Ariston model number on the web, but my Mum insists that the repair man checked with Ariston, and this is indeed correct. The oven is about 8 years old.
    Lots of RH springs are available, but no LH springs.
    Can anyone help?
    #281182
    Re: Door Hinge Spring Ariston Oven
    I assume you mean the grill door, the oven opens sideways.
    Grill door hinge. LH is C00152853…RH is C00152854 The left hand spring is obsolete. 😥
    The main oven door has two different part numbers for top & bottom hinge as well.
    Its actually a model TC714/2 😉
    BrumJim
    Thanks of the quick response. Yes, must be the grill/second oven(?) door. Mum complains that it is flopping down and won’t stay up.
    Thanks for the part number and model number information too.
    Yes, the left hand spring might be obsolete, but it is still needed to keep the door up.
    Any idea how I can get one? Even getting one manufactured might be cheaper than getting a new oven!!
    #281184
    Strange why the left hand one is obsolete and not the right. ❓
    Getting one ‘made’ would be very difficult. Not seen one of those close up so cannot suggest any alternative.
    BrumJim
    OK, I think I have found one on Amazon (amongst the books and CD’s??). Also one is quoted here:
    <a href="http://www.mytub.co.uk/product_information.php?product=372830
    ” target=”_blank” rel=”nofollow”>http://www.mytub.co.uk/product_information.php?product=372830
    It talks about Indesit, but the part number and description appear to be remarkably similar.
    Anyone want one as a template? Is the LH obsolete because it is always breaking (design flaw) and they have run out?
    #281186
    Thats the hinge, not the spring.
    #281187
    BrumJim
    Am I correct in thinking that the hinge is separate from the spring?
    Got a Part Number for the spring?
    #281188
    Unlike most cooker hinges this one has a hinge, pin and spring, all separate parts.
    Unfortunately when a part is declared obsolete the number is removed from the parts ID software and replaced with the word obsolete. 😥
    BrumJim
    Well, fitted this one, this weekend:
    http://www.4ariston.co.uk/cgi-bin/product.pl?PID=580941&query=Ariston{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20TC712&model=TC712&path=76561
    although not from this supplier.
    Although it is supposedly not for this oven, it looked remarkably similar to the broken one that I removed (apart from not being broken, that is). All seems OK at the moment.
