Door interlock – fitting spare
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Door interlock – fitting spare
  • #93280
    Winless
    Hi!
    I recently bought the part “compatible washing machine door lock BS6211” to repair my Bosch WFF2000GB/12.
    This model has a door release button instead of a door handle. I can’t see how to attach the cable for this (Bowden cable?) to the new part as it is very different from the part I am replacing (pics attached, hopefully!). Can anyone advise?
    Thank you!
    #453784
    Re: Door interlock – fitting spare
    where did you get the lock from?
    from the pictures you have they may have sent you the wrong part
    https://shop.ukwhitegoods.co.uk/154077- … lock-13371
    look at the picture of the same part number here
    Winless
    Hi Dave!
    The spare was from UK Whitegoods. I think the angles are what makes them look different – I’ve tried again, matching the angle from the site as best I can (this time without the original part for comparison)
    The metal section on mine is silvery rather than the more golden colour on the listing, but that aside they seem very similar.
    #453786
    on the whitegoods picture it shows a small cover. I would look behind this cover to see what is there to connect the cable to
    but
    you lock does not seem to have this cover
    Winless
    Sorry, taking me a while to get to grips with the images :-/
    #453788
    Winless
    And with the cover carefully removed
    #453789
    Wrong part, send it back and reorder 154077
    #453790
    Winless
    Thank you, Martin! I’ll contact them about a return.
    #453791
    Winless
    in the course of discussion about the return of BS62111 to order 154077, the price of the latter has shot up from £27.77 to £44.95 😯 think this washing machine’s time may be up
    #453792
    a lot of sites seem to say bs62111 will replace 154077.
    possible 154077 is used on some machines with a door handle and therefore it would work but not where its cable operated
    part from Bosch direct £41.38 no p&p
    If you type the part no on Google you can find it cheaper 😉
    #453794
    Winless
    Thanks!!!
