Door interlock replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Door interlock replacement
  • #87649
    Donnelly.gail
    I have a Hoover dyn7125d-s front load washing machine. I have just replaced the door interlock but the interlock is still flashing on the control panel, do I need to run a diagnostic fix before it will work.
    Thanks in advance
    Gail
    #435543
    Re: Door interlock replacement
    You can’t do that because the faulty door lock problem won’t allow access. 🙁
    It could well be that the faulty interlock has blown the circuit board. Remove it and check for blown triac.
