Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Door latch ‘disconnected’ – Fagor FU-4613
- This topic has 7 replies, 3 voices, and was last updated 15 years, 6 months ago by
mattie_uk.
September 16, 2010 at 12:05 pm #57284
mattie_uk
ParticipantHi all
The door latch on my machine isn’t working, previously it felt like it was ‘pulling’ against something but now it’s totally free but doesn’t open the door.
I suspect a breakage somewhere in the mechanism, does anyone know a good place to locate replacement parts and how easy they are to fit/fix? If it’s just a broken piece of plastic I might try superglue.
Not sure how it would have broken, can only assume someone tried to open it before the machine had finished and pulled a bit too hard!
My second question – and perhaps more pressing – how do I now open the door to get the clean washing out?!
All advice gratefully received
Matt
September 18, 2010 at 9:34 am #330486mr mag00
ParticipantRe: Door latch ‘disconnected’ – Fagor FU-4613
how verystrange as this happened to us yesterday, same model, i am here searching www for an answer and found this forum.
i hope someone can help, waiting now ’til monday for fagor to agree our extended warranty is in tact :rolls:but it does look like there are lots of unanswered threads here too 🙁
so any answers anyone, its the weekend and washng needs to be done 😳September 18, 2010 at 2:32 pm #330487mr mag00
hi mattie. i have taken the top off my machine.
to do this you need a size 20 hex drive. undo the two drive toward the rear on the side of the machine. and then lift the front os held on by plastic clips.
disconnect from the power.
looking down at the door mech you will see the white eletronic door lock then within that you will see the black other half of the handle which seems broken from outside of the door.
then within that black pastic mech you can see the metal hook of the latch. push that toward the drum and hey presto the door will pop open and clothes are free.
now to take apart the door!!September 18, 2010 at 3:11 pm #330488mr mag00
this is what you need http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1572931&query=dedietrich{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20fu-3613x
September 19, 2010 at 1:39 pm #330489mattie_uk
Thanks mr mag00
I had to pop out and buy a hex drive set, once I had one it was pretty easy to pop the door. Taking the door apart was simple, just undo the hex bolts and the frame divides into two (careful not to let the glass dome drop!) and these can be taken off the hinge. The handle is held down by another hex bolt.
Now to change the handle. It looks pretty straight-forward, but I must say I’m far from convinced by the design – the loaded edge is pretty thin, no wonder it cracked! Sadly it broke into pieces, so no chance of glueing.
Cheers also for link, I’ll put an order in ASAP.
eta: good luck with warranty!
September 19, 2010 at 7:23 pm #330490gandh1
I HOPE YOU BOTH UNPLUGGED YOUR WASHING MACHINES FIRST!
AN ESSENTIAL THING TO DO WITH DIY REPAIRS :zap:
September 20, 2010 at 7:14 am #330491mr mag00
3rd line in my reply ghand1, thanks for your concern!
@ mattie, yh very weak design, but that i guess is where they make money on parts !October 6, 2010 at 1:00 pm #330492mattie_uk
Hmmm.
I’ve used the machine a few times whilst we wait for the replacement handle (popping the door open form inside the casing). It worked OK for a while, now it gives an error message to the effect that the door’s not closed. I’ve checked, the latch has caught and the door seems secure, but the error message remains.
Two possibilities suggest themselves:
I took the door apart to check the latch mechanism, and refitted – could something not be lined up correctly,perhaps slipping after a few uses after rebuild of the door?I use a small screwdriver to open the latch via the top of the machine as a temporary measure, is it possible I’ve damaged the interlock or some sensors through heavy-handedness?
All ideas of what (and, ideally, how) to check would be appreciated.
(Machine is playing a few other silly tricks so may look for a replacement if this is in any way complicated)
Many thanks
