Door latch-reversed logic?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Door latch-reversed logic?
  • #98959
    Dirtydishesnow
    My Sharp dishwasher failed to start the other day. Giving a single beep each time I tried to select a program.
    I tried to close the door to cycle the program incase it hadn’t finished its last wash (family frequently opening it and taking stuff out).
    It wouldn’t latch. No amount of pushing in would get the door to latch. Striker good, seal good, hinges good, no objects or obstructions.
    So I decided to trigger the latch with a flat butter knife to see if the mechanism was jammed. It moved through fine and the contact switch could be heard clicking. Then the program lights went out. I cycled the power but still nothing until the unit started running with the door open.
    I found that when I have the power on the machine tries to start its program even with the door open. It’s not just the drain pump but actual wash cycle comes on.
    If i place something in the latch it goes off and appears in the open door mode.
    So now it is as if the logic circuit is reversed. Works with door open, not with door closed (simulated with something inserted in catch).
    Being as though the catch isn’t latching and the safety switch logic is reversed, can I conclude it’s a latch problem?
    Rather than a board problem?
    The machine isn’t that old but I’ve identified the latch at £16 new delivered with integral switch.
    #474500
    don
    The model number would help.
    Some of the Sharp products did have a five year parts and labour guarantee, how old is yours?
    Don
    #474501
    Dirtydishesnow
    don wrote:The model number would help.
    Don
    hey Don,
    yeah sorry, thought they would be much of a muchness on this type of thing.
    It’s a sharp QW-D21l492X
    It’s in the region of about 18-24months old.
    #474502
    Dirtydishesnow
    Yeah ordered it in March 2018 and it’s a 12 month warranty so attacked it with the screw driver.
    Turned out to be the latch had pushed right back and was constantly engaging the microswitches.
    Reset and tested it a few times before building back up.
    All working now.
    FIXED
