Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Door lock wma 63
- This topic has 11 replies, 2 voices, and was last updated 19 years, 10 months ago by
hotpointless.
June 10, 2006 at 1:52 pm #18401
hotpointless
ParticipantThe locking light on my wma 63 will not go off. The machine has finished its spin cycle, displayed end but the door did not unlock. As far as I can tell there is no water left in the machine. Anybody got any Ideas as how to get this fixed?
Its Saturday England are playing footy and I live in the middle of nowhere I need some help to get my washing out.
Cheers
AlexJune 10, 2006 at 1:55 pm #178884Penguin45
ParticipantRe: Door lock wma 63
Try a sharp rap on the cabinet next to the door handle – may ping it free. If it does, do not re-use the machine until the lock is replaced.
Can I go back for the second half now?
June 10, 2006 at 1:59 pm #178885hotpointless
Thanks Penguin45 for a brilliantly quick response.
Whats more it worked cheers.
Any idea why this happened and will it happen again?
AlexJune 10, 2006 at 2:00 pm #178886hotpointless
PS enjoy the 2nd half hope we score a few more.
AlexJune 10, 2006 at 2:14 pm #178887hotpointless
Found out when I took Out the washing that there was about a gallon of water left in I have syphoned it out via the normal waste pipe so no blockages. Could this be a one off?
Any other thoughts?
AlexJune 10, 2006 at 3:32 pm #178888Penguin45
Any lights flashing?
June 10, 2006 at 5:40 pm #178889hotpointless
No flashing lights.
I have just run another load of washing and the machine once again did not empty, although it had the END light on. The water I emptied out through the waste tube was very dirty as though it had not been rinsed.
We have had to replace a lifter recently as one came off during a run and shredded a t-shirt, could anything have got in and blocked an outlet or something?
AlexJune 10, 2006 at 6:05 pm #178890Penguin45
Set it to spin only – you should hear the drain pump running. If it had eaten a teeshirt or other large object, the filter would be full and the water would not drain manually. More likely small object jamming the pump.
Power off if dismantling…..
June 10, 2006 at 6:48 pm #178891hotpointless
I have set it to spin only and I can hear the pump, It makes a strange noise and doesn’t totally empty the machine.
Can I get to the pump to see if anything is jamming it.
Can I also check the filter
AlexJune 10, 2006 at 8:20 pm #178892Penguin45
I can’t tell you blow by blow how to do it. However, if you remove the rear lower panel all will be revealed. 😀
Power off, please.
Penguin45.June 11, 2006 at 11:55 am #178893hotpointless
Hi Penguin45
Thanks so much!
Took it all apart, found a piece of the T-shirt 6″ long in the pump itself and more T-shirt and coins, plastic, blutack, and silver paper in the filter.
Works perfectly now
Cheers 😆 😆 😆 😆 😆
June 11, 2006 at 2:11 pm #178894Penguin45
Well done.
P45. -
