“Door locked” flashing on hotpoint WMA52
Home Forums Public Support Forums Help And Support Washing Machine Help Forum “Door locked” flashing on hotpoint WMA52
  • #83179
    P_Fitz
    Hi, I’ve a hotpoint WMA52 washing machine. A few days ago the spring that holds up the drum snapped and the fuse blew on the plug. I installed a new spring but now I get “door locked” flashing when I try to turn it on. It’s the same for all cycles. I had this problem in the past where the “door locked” led started flashing but with a good push on the door it would work. I then replaced the door interlock but this didn’t fix the fault. The latch (that’s probably the wrong word for it) on the door seams to be okay. Any help would be much appreciated.
    #421955
    Re: "Door locked" flashing on hotpoint WMA52
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain that the original door interlock has failed and blown the control pcb. 🙁
    #421956
    P_Fitz
    do you reckon it’s time for a new machine? or is changing the PCB an option.
    Thanks for the reply by the way.
    #421957
    An expensive option, would depend on the overall condition of the motor/main bearings etc.
    #421958
    P_Fitz
    I think I’ll cut my loses and get a new one. Thanks for your help.
