door not auto opening post clearing a blockage_ ISE1606W
Home Forums Public Support Forums Help And Support Washing Machine Help Forum door not auto opening post clearing a blockage_ ISE1606W
  • #95563
    azula
    I bought my ISE 1606W washing machine May 2009 from UK White Goods.
    I have been happy with it.
    Yesterday the drainage became blocked. I looked at the filter in front of the drainage pump. I could not move it. I googled a bit and realised that it should be removable. I found a lot of debris around it. (I had washed bath rug that should have just been thrown.) I removed the debris and have since been able to operate the machine. However, the door now does not click open now at the end of the wash, even though the display say “End”. I have to manually use the button on the front to open the machine. (The little red plastic thing near drainage pump opens the door also.)
    I would prefer for the door to open at the end of the complete wash.
    Is this rectifiable?
    #460751
    Do you still have your user manual? I think it is on page #18 that refers to door settings.
    Turn OFF the machine using the main power switch.
    Press and hold the SUPER RINSE button then switch on.
    AdO is shown if set to auto open, AdF is shown if auto open is not activated. Press the SUPER RINSE button to change the setting.
    Press the DOOR OPENING button to save the setting.
    #460752
    Yes, just checked and those instructions are for W1607 sorry, give a me few minutes and I will see what I can find. I’m guessing you can’t find your instruction manual?
    #460753
    For a W1606.
    Automatic door opening
    The machine comes with an automatic door
    opening function, which means that the door
    opens automatically once the programme has
    finished.
    If you wish to prevent small children or pets
    from climbing into the machine, you can deactivate
    the automatic door opening function.
    1. Turn off the machine using the main power
    switch.
    2. Press the Door Open button while simultaneously
    pressing the main power switch.
    Release the buttons.
    3. Press the Key button and the red field goes
    out. Automatic door opening is now deactivated.
    4. Press the Start/Stop button to store the
    setting.
    If you want to reactivate the function, follow
    the instructions above. When you press the
    button with the key symbol (point 3), the red
    fields light up. Store the setting by pressing
    the Start/stop button.
    #460754
    azula
    Well i came to the right place. After some fiddling around got it to work. I have the manual – well it is just the Operating Instructions booklet but I could find nothing about the door in there except the emergency release pull. I will add this info to the notes section.
    A 1000 thanks !
    #460755
    That info was from the user manual, if you let me have an email address I can send you a pdf of the full manual if you can’t find that info in yours Send me a private message. Off for a game of squash now, will catch up later.
    #460756
    azula
    Many thanks, that will be great. pm sent.
    #460757
    Before I send it just check page #6 of your manual, under Child Safety. 😉
    #460758
    azula
    Ah yes the info is under “Child Safety”. I never thought to look there.
    Thank you for all your help !
