Door problem with Whirlpool ADG 957
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Door problem with Whirlpool ADG 957
  • #32662
    normansbaby
    Hi,I have a built in ADG 957 and it appears the door has come away from a hinge or bracket at the bottom left hand side.When I lower it it is in the correct place but as it raise it “pops” out.I think some sort of spring or something has broken,also I have tried to look with a torch and it looks like a metal strip has broken compared to the right hand side.
    There was a lot of grinding noise before it went.
    Any thoughts on whether it can be fixed and whether I could do it myself?
    #235914
    Re: Door problem with Whirlpool ADG 957
    You’ll need one of these for sure:
    http://shop.ukwhitegoods.co.uk/product_ … ts_id=1480
    And one of these, probably:
    http://shop.ukwhitegoods.co.uk/product_ … ts_id=1481
    Remove side panel to investigate.
    Power off at all times.
