Door Seal for a Whirlpool washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Door Seal for a Whirlpool washing machine
  • #26526
    freddiecat
    I have a WHIRLPOOL AWM 822 washing machine which has a leaking door please can you advise how to fit a new door seal.
    Many thanks.
    #210469
    Goatboy
    Re: Door Seal for a Whirlpool washing machine
    Is the door seal damaged?
    #210470
    freddiecat
    As far as we can see there is no damage to the door seal but it seems to be the only option we can think of to stop the leak. (Have cleaned the door , fitted new spring on catch which was broken) It has leaked for some time but seems to have got worse recently.
    #210471
    johnmac11
    If the face of the seal looks OK it is usualy the soap dispenser that is casing the problem. When you get the leak look closely at the area between the door and the control panel at 11 o’clock for a slight trickle of water, if there is water trickling down from the panel to behind the door then give the soap drawer a good clean.
    If the bottom of the drawer or the jets on top get blocked it will cause a leak that runs along the bottom of the fascia and then goes down behind the door making you think it is the door seal at fault.
    John
    #210472
    freddiecat
    Thanks for your suggestion, I’ve thoroughly cleaned the soap dispenser anyway, but unfortunately still leaking!!
    #210473
    helo_75
    cleaning the dispenser wont stop it leaking,…. they just leak, and no1 knows why
    buy a new one, itll look identical, fit it, it wont leak again!!
    #210474
    freddiecat
    PLEASE is there anyone who can explain how to remove the old door seal and fit a new one (I’m having to wash everything on the quickest wash!)
    #210475
    Remove wire from under door seal front lip. Undo two screws for door lock. Remove kick panel. Undo three screws. Front will fall off. Pull plug first.
    freddiecat
    Thanks for your help, hopefully replacing the seal will solve the problem.
