Door seal for Electra E83/36F
Home Forums Public Support Forums Spare Parts Help Door seal for Electra E83/36F
  • #28147
    crazedscot
    I’m looking for a replacement door seal for an Electra E83/36F, seems to be a rebranded Candy/Kelvinator far as I can tell. Can anyone point me in the right direction? Thanks.
    Richard
    #217119
    Dales-Electronic
    Re: Door seal for Electra E83/36F
    Fridge door seal part number is 97031306, freezer door seal is 97020390 both avail able through the shop to your left ‘Shop@’ you may have to wait abit as I doubt anyone has them in stock.
    #217120
    crazedscot
    Espares seem to have a fridge door seal with that part number that seems to be an OEM part for Hoover fridges, though is listed as fitting various makes of Candy fridges as well. Is it safe to assume this is still the part I need?
    #217121
    Dales-Electronic
    Hoover and Candy are in same group.
    #217122
    crazedscot
    Dales-Electronic wrote:Fridge door seal part number is 97031306, freezer door seal is 97020390 both avail able through the shop to your left ‘Shop@’ you may have to wait abit as I doubt anyone has them in stock.
    For the record, finally got round to ordering a fridge door seal with that exact part number from Espares a couple of weeks ago and just had a go at replacing it, which should have been fairly straightforward…..
    ….It doesn’t fit! The old seal’s entirely rubber, the replacement’s plastic around the edges which just simply doesn’t fit in the top and bottom spaces on my particular fridge door due to the construction, and on top of that it’s a few mm wide so even if I could get it to fit, i’d be dubious of whether it would be airtight. 😕
