I an unable to remove the wire holding the rubber door seal to the front of the machine. The clip holding it in place looks like a small piece of ribbed metal about 3 inches in length . How do you remove this clip?
Its not the spring type or the teeth type.
:con: Manual only shows the ‘zipper’ type clamp, not seen any other kind on late WMA’s. ❓
What do you mean by the toothed type clip, the early wire type with a two piece plastic clip at the top ?
The zipper type clamp has a small metal plate located next to the door hinge, you have to use a small terminal screwdriver to prise one of the hooked ends of the wire out. Refit using long nosed pliers.
