Re: Door seal spring loop replacement trick
4 hands are better than two, remove the door for easier access if needed. two people using one hand to hold spring in place and the other to stretch it working from top to bottom. this is the easy way, if your on your own your going to struggle. a block of wood cut to size to wedge from corner of cabinet to hold spring in place whilst you work around may also work. lots of swearing, sweat and aching hands, good luck.
