Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Door Sizes for a 50/50 Integrated Fridge Freezer?
- This topic has 4 replies, 4 voices, and was last updated 10 years, 5 months ago by
adzyp.
November 8, 2015 at 11:54 am #86609
adzyp
ParticipantHi,
We’ve just replaced our 70/30 integrated with a 50/50 to get more freezer space however obviously our original cupboard doors no longer fit the ff doors. For now i dont mind opening 2 doors to get into the fridge but in the long run want to try and get the doors replaced.
What im struggling to find though is what size doors i need, the current doors have a combined length of 197cm but its not as straight forward as just splitting that into 2 as i have a shelf area above our fridge freezer so the top door would need to be longer.
Am i looking at getting a custom sized top door or is this standard? What is the standard size of the bottom half?
November 8, 2015 at 12:55 pm #432346Martin
ParticipantRe: Door Sizes for a 50/50 Integrated Fridge Freezer?
What is the make and model of this f/freezer? Normally the installation instructions provided will explain the sizes required.
November 8, 2015 at 2:02 pm #432347adzyp
Martin wrote:What is the make and model of this f/freezer? Normally the installation instructions provided will explain the sizes required.
Sorrt, its a whirlpool ART4500A+
January 8, 2016 at 8:26 pm #432348Huntsmore
Hello
I’m looking for some advice in replacing a very old integrated fridge freezer. It is an AEG 170 i (fridge portion anyway) E-Nr 621 303 104. I can’t find the freezer model but the size is the same as the above I believe. Given that this was probably installed almost 30 years ago I want to ensure a new integrated would fit into the same space. I’ve measured the doors and they seem to be h 93.5 cm x w 60 cm for the fridge and h 94 cm x w 60 cm for the freezer. As this runs larger than most of the heights I’ve seen in new models I didn’t want to rush in and buy before I was sure. The fridge freezer is a sliding type.
I’ve looked online to see if I can find any old installation instructions that may give dimensions but I can only find a operators manual.
Thanks!
January 9, 2016 at 9:01 am #432349don
ModeratorRe: Door Sizes for a 50/50 Integrated Fridge Freezer?
Seems like you have a standard 50:50 split appliance. But to make sure I would ask AEG help section here for the correct advice before proceeding.
Like you all I can find is the user manual which is about as much help……………………..
Slider fitting is the most popular one so replacing it should not be a great problem.HTH 😀
Don
