Door trim
  • #6452
    cornwell40
    Anyone got a part number for phillips AWB947 door trim in brown?
    Much thanks in advance.
    Tony C
    #117726
    Dave_Conway
    Re: Door trim
    Which one Tony ?
    The “hollow” one that the inner clips in to or the one with six (I think) screw holes around the inside.
    #117727
    Re: Door trim
    awb 947’s door rims are a minefield!
    #117728
    cornwell40
    Re: Door trim
    Its a customer order and she wants the outer brown one. Methinks we need more info 🙄
    Tony C
    #117729
    Re: Door trim
    if its only cracked where the door spring tensions, (the usual reason for changing the door rim) then you can get a little mod kit that saves the door rim. 481931038624.
