Door wont open after fusing Hotpoint wd420
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Door wont open after fusing Hotpoint wd420
  • #32559
    progomez
    My washer was washing and then started tripping the fuse. Switched it off and opened the door and removed clothes.
    I then pulled it out, opened the top and noticed a loose wire(blue). replaced this and it started to work again.
    Problem is that the door wont open. I have put it through a wash cycle and had it switched off for an hour.
    The door locked light is always on.
    Any ideas, thanks.
    Can it be opened from inside?
    #235579
    kiddo66
    Re: Door wont open after fusing Hotpoint wd420
    You can open them from the inside,there is a little locking tab on the back of the door interlock that you can push in and it will open,but im more worried about this blue wire you have found.Some of those machines have test plugs in them that are intentionally not connected.
    I would call someone in if i were you…..
    Power off before touching anything.
