Hello again!
This is my other fridge that I am working on. I have re done the door but it dose not shut properly! only when it is turned upside down door facing flat.
Is there some kind of clip that would work at all?
electrofix wrote: if the door is twisted it wont seal properly
you could warm the seal to see if it stretches
Is it possible I twisted the door when cutting it?
What do you recomend I warm the seal up with; presuming it needs warming up while it is in place and not out of the door
with the older screwed doors you had to leave the screws slightly loose and then close the door and twist it till its even. then carefully open the door and tighten a few screws and check it again. if all well tighten them all
As said before its often necessary to warm new door seals to soften them to allow them to stretch to seal
