Doplomat Fridge Freezer Puddle
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Doplomat Fridge Freezer Puddle
  • #10348
    Puddle keeps forming at bottom of fridge, don’t know why, hole is clear.
    #139581
    DentedPorsche
    Re: Doplomat Fridge Freezer Puddle
    Have you checked that the hose attached to it is clear? There should be a piece of hose on the rear that runs down to the container on top of the compressor.
    DP
    #139582
    hi
    if you get a longer peice of flexible wire and put it down into the hole and twist the wire when pushing it down you will find that this will clear it.
    bryan
    #139583
    Thanks, the longer wire worked, simple isn’t it.
