Double Door Coke Drinks Display Cabinet – True GDM-35
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Double Door Coke Drinks Display Cabinet – True GDM-35
  • #58137
    RocketMan
    I need to try and source some spares for above fridge. I need at least, the relay starter that that is badly damaged.
    http://www.coldsupply.com/True-802173-S … p_538.html
    I suspect the capapcitor is also dead/damaged as something has shorted to cause the damage. If I can’t a supplier it’s not a lot of use proceeding any further…..
    I have discovered relay failures on these are not uncommon, (US sites) including damage to the compressor stubbs… ermm
    #333516
    Dales-Electronic
    Re: Double Door Coke Drinks Display Cabinet – True GDM-35
    Supco R022 relay and overload assembly will do the job, rated up to half a HP and can be used with a start capacitor. Comes with fitting instructions. HTH
    #333517
    RocketMan
    Thanks for that mate, Where do you get them from?
    Unless I’m being studpid I can’t find them on Masterpart or Europart sites.
    #333518
    Dales-Electronic
    Try – HRP, Dean & Wood or SRW – Probably too high a HP for most of the domestic suppliers 8)
    #333519
    RocketMan
    Thanks mate,
    you have a pm
