Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Double inlet hose
- This topic has 9 replies, 5 voices, and was last updated 16 years, 2 months ago by
RocketMan.
January 28, 2010 at 5:44 pm #52040
RocketMan
ParticipantHi,
Seen one of these fitted on a WD420. Does anyone know the part number???
Could do with a few for spares
Steve
January 28, 2010 at 5:47 pm #310412iadom
ModeratorRe: Double inlet hose
C00194506. 🙂
January 28, 2010 at 6:19 pm #310413eastlmark
RocketMan wrote:Hi,
Steve
looks like a nasty kink in the making on that one though once its pushed back 😉
January 28, 2010 at 7:46 pm #310414kladave
ParticipantRe: Double inlet hose
Qualtex do one,but i’m at home and have no access to the part number.
Can let you know tomrrow if you want.Dave
January 28, 2010 at 8:01 pm #310415RocketMan
Oh yes, definately was a kink. Made sure it wasn’t kinked when I put it back though. Will go back and put a new one on next time I’m at the flats.
24 in two blocks of flats. Mixture of WD420s/WF321s/CTDs and APM8513/2 – also mix and match ovens and hobs. Each one is installed differently to different standards all around Oct 07. Just waiting for them to all start falling over… Nice little earner, just can’t do the hobs as they’re gas but only had one igniter fail and gas guy around the corner does little jobs for me and I help in out when he needs a hand. Was only there again yesterday, three WMs in a week. 😀 😀 😀C00194506 – cheers Jim – £5.95 plus at MP and special order??? Anywhere else???
January 28, 2010 at 8:14 pm #310416Turbo
C00194506 is £4.29 from connect. I always have one on the van. They are ideal if you are working in a flat with very low water pressure and you are there to change the leaking hot inlet valve. I tell the customer is would be better to go cold water fill only with the use of this hose. Better than those awful “Y” piece connectors. Makes for a really tidy job IMO
Graham
January 28, 2010 at 11:15 pm #310417RocketMan
Thanks felllas, appreciated.
Steve
January 29, 2010 at 12:04 pm #310418kladave
Qualtex part number is FWH41 @£3.49.
January 29, 2010 at 12:06 pm #310419kladave
Connect part number HSE9124
January 29, 2010 at 2:28 pm #310420RocketMan
kladave wrote:Connect part number HSE9124
Hi kladave,
Thank you good sir
