Double oven – main oven cutting out – top oven ok
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Double oven – main oven cutting out – top oven ok
  • #32612
    Luigi
    I have an Electrolux EOD984W approx. 9 years old.
    Main oven cuts out completely (no heat/fan/light) after 30 – 40 minutes or so. Will re-start when cooled down somewhat.
    Top oven will still work though and fan for controls is working fine.
    Is there a separate thermal cut-out for each oven – if so then is this the likely cause?
    Or could it be be the main oven thermostat or something else entirely??
    Advice gratefully received.
    #235766
    Re: Double oven – main oven cutting out – top oven ok
    There is a safety thermostat for the main oven mounted on the back – usually a white ceramic block with a coulple of wires. Given the passage of time before it trips, it may well actually be doing its job – you need to check whether or not the oven thermostat is cycling.
    3115190-05/4 – safety cut-out
    3111622-01/9 – main oven thermostat
    spares@ukwhitegoods.co.uk will be able to supply any parts required.
    Power off if investigating.
    Luigi
    Thanks for the advice. I replaced the saftety cut-out and all seems ok. Main oven run at 220c for an hour and all is fine.
    Will borrow an oven thermometer to check main thermostat but I think it’s ok.
